APC  Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt
Quicklinx: DPYPWS00 Mfr#: SMC1000IC
Power Rating: 600Watt
More than 50 In Stock
£443.17 ex VAT
£531.80 inc VAT
Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Smart-UPS are trusted by millions of IT professionals throughout the world to protect equipment and critical data from costly interruptions by supplying reliable, network-grade power reliably and efficiently.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMC1000IC - UPS - 600 Watt - 1000 VA
UPS - external
17.25 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V
Power Capacity
600 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Lead Acid
Batteries Qty
1
Run Time (Up To)
5 min at full load
USB
21.9 cm x 17.1 cm x 43.9 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 180 - 286 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz ± 3%
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
600 Watt / 1000 VA
Output Waveform
Sinewave
Surge Energy Rating
693 Joules
Quantity
1
Lead Acid
Run Time (Up To)
5 min at full load , 14 min at half load
Remote Management Interface
USB
1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
Audible alarm, LCD display
C-Tick, GOST, VDE
Software Included
APC PowerChute Business Edition
21.9 cm
17.1 cm
43.9 cm
17.25 kg
DPYP APC Basic Rack-Mount PDU - power distribution strip In Stock £201.26
DPYP APC 1U Vertical Cable Organiser In Stock £122.27
DPYP APC 1U Horizontal Cable Organiser In Stock £54.65
DPYP APC Netshelter heavy duty shelf In Stock £142.40
DPYP APC - rack cable guide - 1U In Stock £51.50
DPYP APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.87
DPYP APC Rack PDU Basic Zero U 32A 230V In Stock £319.25
DPYP APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.38
DPYP APC Cable Managers (Qty 10) In Stock £35.20
DPYP APC 2G Power distribution strip In Stock £643.06
DPYP APC Rack PDU 2G METERED ZEROU In Stock £687.07
DPYP APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £980.84
DPYP APC 19" Rack LCD Console In Stock £1,378.32
DPYP APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.63
DPYP APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.81
DPYP APC 1U Blanking Panel Kit In Stock £34.57
DPYP APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.73
DPYP APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.09
DPYP APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,687.54
DPYP APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.74
DPYP APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £625.60
DPYP APC Replacement Battery Cartridge #142 In Stock £121.55
DPYP APC Metered Rack PDU In Stock £842.51
DPYP APC Switched Rack PDU AC 208-230 V Ethernet In Stock £743.24
DPYP APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £263.31
DPYP APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,089.67
DPYP APC 1 Year Extended Warranty 2015-4037 In Stock £62.04
DPYP APC Service Pack 3 Year Warranty Extension In Stock £115.74
DPYP APC Switched PDU 10A 0U C13x16 In Stock £1,157.89
DPYP APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.24
DPYP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,251.94
DPYP APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £160.96
DPYP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,282.18
DPYP APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.63
DPYP APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.83
Brand: APC
