APC  Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt
Quicklinx: DPYPWS00 Mfr#: SMC1000IC
Power Rating: 600Watt
£448.89 ex VAT
£538.66 inc VAT
Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Smart-UPS are trusted by millions of IT professionals throughout the world to protect equipment and critical data from costly interruptions by supplying reliable, network-grade power reliably and efficiently.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMC1000IC - UPS - 600 Watt - 1000 VA
UPS - external
17.25 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V
Power Capacity
600 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Lead Acid
Batteries Qty
1
Run Time (Up To)
5 min at full load
USB
21.9 cm x 17.1 cm x 43.9 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 180 - 286 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz ± 3%
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
600 Watt / 1000 VA
Output Waveform
Sinewave
Surge Energy Rating
693 Joules
Quantity
1
Lead Acid
Run Time (Up To)
5 min at full load , 14 min at half load
Remote Management Interface
USB
1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
Audible alarm, LCD display
C-Tick, GOST, VDE
Software Included
APC PowerChute Business Edition
21.9 cm
17.1 cm
43.9 cm
17.25 kg
DPYP APC Basic Rack-Mount PDU - power distribution strip In Stock £203.85
DPYP APC 1U Vertical Cable Organiser In Stock £124.59
DPYP APC 1U Horizontal Cable Organiser In Stock £55.36
DPYP APC Netshelter heavy duty shelf In Stock £143.47
DPYP APC - rack cable guide - 1U In Stock £51.34
DPYP APC Rack PDU Basic Zero U 16A 208/230V In Stock £298.78
DPYP APC Rack PDU Basic Zero U 32A 230V In Stock £323.36
DPYP APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £288.97
DPYP APC Cable Managers (Qty 10) In Stock £35.65
DPYP APC 2G Power distribution strip In Stock £648.88
DPYP APC Rack PDU 2G METERED ZEROU In Stock £700.20
DPYP APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £993.47
DPYP APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.38
DPYP APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.68
DPYP APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,463.65
DPYP APC NetShelter Zero U Accessory Mounting Bracket In Stock £67.39
DPYP APC 1U Blanking Panel Kit In Stock £35.01
DPYP APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £57.23
DPYP APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.70
DPYP APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
DPYP APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £71.36
DPYP APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £633.65
DPYP APC Replacement Battery Cartridge #142 In Stock £122.46
DPYP APC Metered Rack PDU In Stock £850.13
DPYP APC Switched Rack PDU AC 208-230 V Ethernet In Stock £749.97
DPYP APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,087.72
DPYP APC 1 Year Extended Warranty 2015-4037 In Stock £62.86
DPYP APC Service Pack 3 Year Warranty Extension In Stock £117.04
DPYP APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.99
DPYP APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £674.28
DPYP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,263.27
DPYP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,298.69
DPYP APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.68
DPYP APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.06
Brand: APC
