APC  Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt
Quicklinx: DPYPWS00 Mfr#: SMC1000IC
Power Rating: 600Watt
12 In Stock
£438.36 ex VAT
£526.03 inc VAT
Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Smart-UPS are trusted by millions of IT professionals throughout the world to protect equipment and critical data from costly interruptions by supplying reliable, network-grade power reliably and efficiently.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
APC Smart-UPS SMC1000IC - UPS - 600 Watt - 1000 VA
UPS - external
17.25 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V
Power Capacity
600 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Lead Acid
Batteries Qty
1
Run Time (Up To)
5 min at full load
USB
21.9 cm x 17.1 cm x 43.9 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 180 - 286 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz ± 3%
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
600 Watt / 1000 VA
Output Waveform
Sinewave
Surge Energy Rating
693 Joules
Quantity
1
Lead Acid
Run Time (Up To)
5 min at full load , 14 min at half load
Remote Management Interface
USB
1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
Audible alarm, LCD display
C-Tick, GOST, VDE
Software Included
APC PowerChute Business Edition
21.9 cm
17.1 cm
43.9 cm
17.25 kg
DPYP APC Basic Rack-Mount PDU - power distribution strip In Stock £200.74
DPYP APC 1U Vertical Cable Organiser In Stock £119.81
DPYP APC 1U Horizontal Cable Organiser In Stock £54.38
DPYP APC Rack PDU Basic Zero U 16A 208/230V In Stock £292.54
DPYP APC Rack PDU Basic Zero U 32A 230V In Stock £314.25
DPYP APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £281.45
DPYP APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; In Stock £317.76
DPYP APC Cable Managers (Qty 10) In Stock £35.29
DPYP APC 2G Power distribution strip In Stock £627.52
DPYP APC 2U Horizontal Cable Organizer In Stock £57.58
DPYP APC Rack PDU 2G METERED ZEROU In Stock £672.12
DPYP APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £960.61
DPYP APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £922.94
DPYP APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch In Stock £1,926.60
DPYP APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,442.54
DPYP APC NetShelter Zero U Accessory Mounting Bracket In Stock £64.95
DPYP APC Blanking Panel Kit In Stock £107.35
DPYP APC 1U Blanking Panel Kit In Stock £33.57
DPYP APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.06
DPYP APC Basic Rack PDU Zero U - Power Distribution Panel In Stock £350.93
DPYP APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,661.01
DPYP APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £618.51
DPYP APC Replacement Battery Cartridge #142 In Stock £115.99
DPYP APC Metered Rack PDU In Stock £825.58
DPYP APC Switched Rack PDU AC 208-230 V Ethernet In Stock £727.91
DPYP APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £255.12
DPYP APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,070.54
DPYP APC 1 Year Extended Warranty 2015-4037 In Stock £56.73
DPYP APC Service Pack 3 Year Warranty Extension In Stock £114.56
DPYP APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £644.38
DPYP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.34
DPYP APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £156.86
DPYP APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.80
Brand: APC
