MMO GAMING MOUSE
- 16 fully-programmable gaming buttons
- Fine-tuned ergonomics for MMORPG game titles
- Advanced 8200dpi Laser Sensor
- Ultra-durable 20 million clicks Omron switch
Fine-tuned Ergonomics
Create for MMORPG game titles, well located buttons offer instant execution of the gaming commands.
16 fully-programmable Gaming Buttons
All keys on THUNDER M7 are programmable via AORUS macro engine to ensure the maximal flexibility for customizing personal skillsets.
Top-of-the-line Gaming Laser Sensor
Advanced laser sensor supporting up to 8200dpi resolution and 150ips lightning fast tracking speed ensures efficient and smooth movement on your multi-screens or the most high resolution monitors.
On-the-fly DPI Switching
800/1600/3200/5600DPI adjustable switch with synchronized indicator for quick on the-fly DPI adjustment.
20 million clicks lifetime Omron switch
Ultra-durable 20 million clicks Omron switches not only extend the durability and also perfect the clicking response.
Built-in AORUS Macro Engine
Profile switch at your fingertips enables you to switch between 5 different gaming profiles. Up to 70 macros memorization for the gamer on the go.
Fully programmable gaming buttons
All keys on the THUNDER M7 are programmable to ensure maximal flexibility and customization of your personal skills. -
Gaming laser sensor
Advanced laser sensor and lightning-fast tracking speed ensures efficient and smooth movement on your high-resolution monitors. -
On-the-fly DPI switching
Adjustable switch with synchronized indicator for quick on the-fly DPI adjustment.
- AORUS THUNDER M7 - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 7 cm x 11.6 cm x 4.4 cm
- Movement Detection Technology
- Laser
- Buttons Qty
- 16
- Movement Resolution
- 8200 dpi
- Performance
- 150 inches per second
- Scrolling wheel, on-the-fly DPI switching
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- Mouse
- 7 cm
- 11.6 cm
- 4.4 cm
- Black
Input Device
- Wired
- Interface
- USB
- Laser
- Buttons Qty
- 16
- 8200 dpi
- Performance
- Cable Length
- 1.8 m
- BSMI, FCC, KCC
- Software Included
- AORUS Macro Engine
- OS Required
