The AOC I2276VWM display offers high performance and extra convenience for the most discerning users. This 21.5-inch ADS-IPS monitor delivers sharp contrast ratios, stunning imagery and accurate colors with viewing angles of up to 178 degrees. With Full HD 1920 x 1080 resolution you'll enjoy photos, movies, games and more in gorgeous detail. The fast 5 ms response time makes it ideal for the most demanding applications. Easily connect your computer, media player and game console with the VGA and HDMI ports. The adjustable stand and built-in VESA mount give you the option to use it at your desk or mount it on the wall. From systems integration to family entertainment, this monitor will impress at any office or home.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players. -
MHL Connection
Mobile High-Definition Link (MHL) technology lets you mirror the content from your portable devices directly on this display. Use an MHL cable to connect your smartphone or tablet and bring all your entertainment to life on the large monitor screen with full digital sound. Relax and enjoy your games, movies, photos and apps on the big screen while charging your mobile device at the same time. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
- AOC Value I2276VWM - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 18 W
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, MHL
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.14 cm x 22.1 cm x 40.04 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, GOST, FCC, RoHS, ISO 9241-307, cTUVus, TUV Bauart, EuP, EAC, Ukrain Safety
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 27 kWh
- Diagonal Size
- 21.5"
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care
- Black
- 55.14 cm x 22.1 cm x 40.04 cm - with stand
- VGA , MHL / HDMI (HDCP) , Headphones
Mechanical
- Tilt
- Tilt Angle
- -4/+21.5
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- Power Supply
- Internal
- Input Voltage
- 18 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
Accessories (4)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
Other bundles (1)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
