AOC Value E2370SD 23" 1920x1080 5ms VGA DVI-D LED Monitor
Quicklinx: 96GPWS00 Mfr#: e2370sd
1 on order, delivery delayed
This large widescreen monitor boasts a non-glare LED-backlit TN panel with Full HD resolution. Delivering a response time of only 5 ms and a static contrast of 1000:1, the 70 series member comes well-equipped for both multimedia and office applications. Connecting analog signals via D-Sub and digitally via its DVI port. This energy-efficient display fulfils strict sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold.
  • Vivid visuals
    Experience true-to-life colors with the AOC E2370SD's 23-inch display, boasting a dynamic contrast ratio of 20,000,000:1 and 16.7 million color support. The Full HD 1080p resolution ensures crisp, clear images for an immersive viewing experience.
  • Ergonomic design
    Designed with your comfort in mind, the AOC E2370SD features tilt adjustments allowing you to find the perfect viewing angle, reducing strain during long usage periods.
  • Seamless connectivity
    Equipped with both DVI-D and VGA interfaces, this monitor offers versatile connectivity options, making it easy to connect to a wide range of devices.
AOC E2370SD - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
3-year warranty
Display Type
Diagonal Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
