Expand your possibilities with the spacious 34-inch WQHD monitor. This 21:9 display offers UltraWide 3440 x 1440 resolution for gorgeous detail and more room to get things done. Built-in 7-watt speakers and 1.07 billion colors complete the cinematic experience. The extra space lets you split your screen into multiple panes for increased efficiency. Use picture-by-picture mode to display a spreadsheet and financial software or picture-in-picture to watch a movie while you chat with a friend. Connect devices, peripherals and even a second computer with HDMI, DisplayPort, and USB 3.0. With so much space, you'll always see the big picture.
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of viewing or working comfort. -
WQHD resolution
With 3440 x 1440 resolution, Wide Quad HD (WQHD) offers superior picture quality and crisp imagery that reveals every detail. The widescreen 21:9 aspect ratio is perfect for watching movies in an expansive format or immersing yourself in the latest game, plus it offers more space when it's time to work. True 8-bit colour provides a broad colour palette for vibrant, natural-looking images. -
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
- AOC U3477PQU - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 92 kWh
- Power Consumption (On mode)
- 63 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.2325 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 82.8 cm x 22.92 cm x 62.45 cm
- 10 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, GOST, RoHS, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 92 kWh
- Diagonal Size
- 34"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL)
- Black
- 82.8 cm x 22.92 cm x 62.45 cm - with stand
- 10 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- DVI-D , VGA , MHL / HDMI , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+24
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), built-in speaker, VESA interface support
- Cables Included
- 1 x power cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 63 W
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.1 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
