Enjoy brilliantly colored, vivid images on this large 68.6 cm (27?) widescreen monitor. Boasting a high-grade PLS panel with Full HD resolution, the i2770Pq/BK delivers exceptionally wide viewing angles for multimedia and office applications. With its D-Sub, DVI-D, HDMI connectors as well as speakers integrated into the bezel, this energy-efficient display offers you a multitude of options. Benefit from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot function. The i2770Pq/BK comes in a classy black texturized design and features eco-friendly LED-backlights. Let this stylish monitor impress you today!
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players. -
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
- AOC Professional I2770PQ/BK - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 36.5 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.24 cm x 24.4 cm x 55.6 cm
- 8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 36.5 kWh
- Diagonal Size
- 27"
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
- Black
- 64.24 cm x 24.4 cm x 55.6 cm - with stand
- 8 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (HDCP) , DisplayPort , HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+25
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 25 W
- Power Consumption (Typical)
- 29.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
