The AOC U3277PQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 32-inch 16:9 screen that is ideal for multitasking. Featuring advanced IPS panel technology, you'll enjoy accurate color reproduction (100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a new website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of viewing or working comfort. -
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
- AOC U3277PQU - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class C
- Energy Consumption per Year
- 88 kWh
- Power Consumption (On mode)
- 60 W
- Speaker, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1845 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Black, silver
- 74.188 cm x 17.12 cm x 65.9 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 88 kWh
- Diagonal Size
- 32"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1845 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- 1 billion colours
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Flicker Free technology, Zero power switch
- Black, silver
- 74.188 cm x 17.12 cm x 65.9 cm - with stand
- VGA (HD-15) , MHL / HDMI , DVI-D , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
- VESA Mounting Interface
- Included Accessories
- Stand
- Cables Included
- 1 x power cable , 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 60 W
- Power Consumption (Typical)
- 79 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
