AOC Pro-line Q27P3QW 27" QHD  LED Monitor
Quicklinx: HPSBWS00 Mfr#: Q27P3QW
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
16 In Stock
£192.76 ex VAT
£231.31 inc VAT
The AOC Q27P3QW is a 27" flat-screen IPS monitor with an attractive three-sided ultrathin bezel design that will facilitate and enhance your workday. Enjoy the beauty and detail of QHD (2560 x 1440) resolution, wide viewing angles, and peak 350-nit brightness. This model includes a variety of connectivity options, including a built-in 2MP webcam with Windows Hello for easy remote collaboration coupled with 5W + 5W internal speakers for high-quality sound.
  • QHD Resolution
    With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
  • IPS Panel
    IPS panel ensures an excellent viewing experience with lifelike yet brilliant and accurate colours. Colours look consistent no matter from which angle you look at the display
  • True-to-life collaboration and video calling
    Video calling has never been so lifelike as with an embedded webcam with integrated microphone. Join forces with colleagues and clients from the comfort of your home or office with one simple solution!
  • Security and responsiveness with Windows Hello certified webcam
    Get the best security with Windows Hello facial recognition! An Integrated webcam certified with Windows Hello offers that convenient extra safety, with no need of passwords or PIN.
  • USB Hub
    Built-in USB hubs in AOC's monitors bring ease of use and practicality to your desk. Side mounted ports are easily reachable without even looking at them; negating time wasted searching the backside of a PC case to find a free USB port.
  • Adaptive sync
    Adaptive Sync aligns your monitor's vertical refresh rate with the frame rate delivered by your GPU, making your gameplay and casual gaming experience even more fluid by eliminating stuttering, tearing and judder. This feature is also useful when enjoying videos and other visual media, for a smoother entertainment.
  • 75Hz Refresh Rate
    Get the upper edge! With a 75 Hz refresh rate, the display panel draws 75 frames each second. 75 Hz refresh rate is 25% faster than what is offered on most entry level displays at 60 Hz, while still being affordable and delivering those extra frames gamers need to beat their opponents.
  • Display Port
    DisplayPort offers ultra-fast digital audio and video transmission without quality loss or input lag. Quickly and easily connect a range of devices to your screen, including your computer, laptop, media player, game console and more. It's perfect for professionals as well as the most demanding home users.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • Low Blue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • Frameless design
    Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side.
  • Full Ergonomics
    Feel the comfort! AOC's height, tilt and swivel-adjustable stands help you find the most comfortable and healthy position.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3rd party mounts and stands thanks to the VESA mount option.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
AOC Pro-line Q27P3QW - P3 Series - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
2.0 megapixel camera, USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Built-in Webcam
2 Megapixel
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Pricing Type
B2B
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9
HDCP 1.4
3-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Czech, Croatian, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese
Flicker Free technology, Adaptive-Sync technology, DisplayLink Technology, Low Blue Light technology, 3-sided bezeless
Built-in Webcam
Sensor Resolution
2 Megapixel
Built-in microphone, Windows Hello compatible
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP 1.4) , DisplayPort 1.2 , 4 x USB 3.2 Gen 1 downstream (fast charging) , USB-B
Mechanical
Tilt Angle
-5/+35
Swivel Angle
360
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), textured finish
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
HDCP 1.4
Pricing Type
B2B
Security Slot Type
Kensington security slot
Input Voltage
Sustainability Information
TCO Certified
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Brand: AOC
