AOC Pro-line I2475PRQU 24" 1920x1200 4ms HDMI DVI DisplayPort VGA LED Monitor
Quicklinx: D6WBWS00 Mfr#: I2475PRQU
This model targets business and home office users alike. Hidden behind its classically designed case is the latest IPS technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. The height-adjustable stand tilts, swivels and pivots for optimal comfort.
AOC Pro-line I2475PRQU - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Voltage
Textured black
55.9 cm x 13.9 cm x 53.4 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class A
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Flicker Free technology
Textured black
55.9 cm x 13.9 cm x 53.4 cm - with stand
6.2 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI , HDMI , VGA , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
