AOC Pro-line I2375PQU 23" 1920x1080 5ms HDMI DVI DisplayPort VGA LED Monitor
Quicklinx: D6W8WS00 Mfr#: I2375PQU
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Hurry, only 2 left in stock!
£138.01 ex VAT
£165.61 inc VAT
This IPS monitor offers wide viewing angles. It boasts a variety of connectors including DisplayPort and a USB hub. It also features a height-adjustable stand and speakers.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • IPS panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favorite game - your content will look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colors and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you - or your friends and co-workers sitting or standing next to you - are looking at the screen.
  • Height adjustable stand
    This monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
AOC Pro-line I2375PQU - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
53.25 cm x 21.29 cm x 48.75 cm
4.92 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC, TCO Displays 7.0
3-year warranty
Display Type
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Flicker Free technology
53.25 cm x 21.29 cm x 48.75 cm - with stand
4.92 kg
Audio
Speakers
DVI , DisplayPort , VGA , HDMI , USB 2.0 , USB 3.0
Mechanical
Tilt Angle
-5/+21
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
AC 100/240 V (50/60 Hz)
18 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
AOC Pro-line I2375PQU 23 Bundle deal on AOC Pro-line I2375PQU 23" 1920x1080 5ms HDMI DVI DisplayPort VGA LED Monitor
£237.18
Diagonal Size: 23in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
