AOC Pro-line I2275PWQU 21.5" 1920x1080 4ms HDMI DVI-D VGA DisplayPort LED Monitor
Quicklinx: D6W7WS00 Mfr#: i2275PWQU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£116.57 ex VAT
£139.88 inc VAT
This versatile 21.5-inch IPS display offers excellent performance for any task. Full HD resolution, high contrast ratios and wide viewing angles produce sharp, vivid imagery. A wide range of connectors, including DisplayPort, DVI, HDMI and USB (2.0 and 3.0) make it easy to hook up your computer and other devices.
Display Type
LCD monitor
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
HDCP, i-Menu, e-Saver technology
50.4 cm x 21.29 cm x 46.88 cm - with stand
4.97 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI-D , HDMI , VGA , DisplayPort , Audio line-in , 4 x USB 3.0
Mechanical
Display Position Adjustments
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB 3.1 cable , 1 x audio cable , 1 x DisplayPort cable
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
14 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Environmental Standards
ENERGY STAR Certified
Limited warranty - 3 years
AOC Pro-line I2275PWQU 21.5 Bundle deal on AOC Pro-line I2275PWQU 21.5" 1920x1080 4ms HDMI DVI-D VGA DisplayPort LED Monitor
£215.74
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
