AOC Pro-line E2275PWQU LCD Monitor 21.5" 1920 x 1080 5
Quicklinx: CHDPWS00 Mfr#: E2275PWQU
This high-performance office display combines convenience with superior picture quality. With optimized brightness and high contrast ratios, the 21.5-inch E2275PWQU delivers sharp, vivid imagery in Full HD (1920 x 1080) resolution. Fast 2ms response time handles videos, animations and the most demanding software applications with ease. Integrated VGA, DVI and HDMI connectors plus USB 2.0 and 3.0 ports make it easy to connect a computer, laptop and a range of other devices. The built-in speakers and headphone jack offer extra convenience for online calls and more. To keep you working in comfort, Flicker Free technology helps reduce eye fatigue.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Display Port
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
  • USB Hub
    Built-in USB hubs in AOC's monitors bring ease of use and practicality to your desk. Side mounted ports are easily reachable without even looking at them; negating time wasted searching the backside of a PC case to find a free USB port.
AOC Pro-line E2275PWQU - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Energy Class
Class A
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Voltage
50.4 cm x 46.88 cm x 21.29 cm
4.97 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class A
Diagonal Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
HDCP, i-Menu, e-Saver technology, Flicker Free technology
50.4 cm x 46.88 cm x 21.29 cm - with stand
4.97 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI , HDMI , VGA , 4 x USB 3.0 , Audio line-in
Mechanical
Tilt Angle
-5/+25
Swivel Angle
330
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x SuperSpeed USB cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
