This model targets business and home office users alike. Hidden behind its classically designed case is the panel technology. It boasts a high typical contrast, Full HD resolution, a fast response time and wide viewing angles for amazing imaging performance.
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Full HD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
- AOC Pro-line M2060PWDA2 - LED monitor - Full HD (1080p) - 19.53"
- LED-backlit LCD monitor - 19.53"
- Energy Class
- Class E
- Power Consumption (On mode)
- 13.4 W
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 47.76 cm x 35.83 cm x 17.95 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV, RoHS
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19.53"
- Built-in Devices
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 7 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP, i-Care
- 47.76 cm x 35.83 cm x 17.95 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA ¦ DVI
Mechanical
- Tilt Angle
- -5/+22
- Cables Included
- 1 x VGA cable ¦ 1 x DVI cable ¦ 1 x audio cable
- Input Voltage
- 13.4 W
- Power Consumption SDR (On mode)
- 13.4 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
