This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
- AOC Pro-line I960PRDA - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/405248
- Energy Class
- Class E
- Power Consumption (On mode)
- 14.6 W
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel
- Voltage
- AC 230V (50/60 Hz)
- Black
- 40.92 cm x 43.22 cm x 21 cm
- 4.77 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 140 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- I-Menu, e-Saver technology, Eco Saving, Screen+, i-Care
- Black
- 4.77 kg
Audio
- Speakers
- VGA , DVI-D , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x power cable
- Power Supply
- Internal
- Input Voltage
- 14.6 W
- Power Consumption SDR (On mode)
- 14.6 kWh/1000h
- Power Consumption (Typical)
- 16 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.21 Watt
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £6.80 |
