This Full HD monitor blows the contents of your Android devices up to an impressive size: With the innovative MHL™ interface (Mobile High-Definition Link) high-resolution photos, videos and games can be displayed directly from a smartphone or tablet PC on the huge 68.6 cm (27?) screen. A practical side effect: the mobile gadgets get charged at the same time. The LED model utilises the high-quality IPS display technology, which, besides providing a strong contrast und a brightness of 250 cd/m², stands for exceptionally good colour fidelity and viewing angle stability. A big stage for your photos and videos!
Product Details
- Inputs: D-SUB, HDMI
- 1920 x 1080 maximum resolution
- Special Features: audio out, DCR, Eco Mode, e-Saver, i-Menu, MHL, screen+, Kensington Security Lock, Headphone out
- 250 cd/m²
- 5ms GtG
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players. -
Touch Key
Access the display functions with sleek, touch-sensitive buttons that blend seamlessly into the frame.
- AOC myPlay I2757FM - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 46 kWh
- Power Consumption (On mode)
- 32 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 62.2 cm x 13 cm x 44.9 cm
- 5.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, BSMI, DDC-2B, CCC, FCC, DDC/CI, ISO 9241-307, CEL, cCSAus, EPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 46 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, input select
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP
- Black, silver
- 5.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , 2 x HDMI (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Input Voltage
- 32 W
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- On / Off Switch
- No
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
