AOC G2460PF 24" 1920x1080 1ms VGA DVI HDMI Gaming Monitor
Quicklinx: C29NWS00 Mfr#: G2460PF
Designed for serious gamers, the 24-inch AOC G2460PF display delivers an extra smooth playing experience with AMD FreeSync. Combined with an AMD Radeon graphics card and AMD Catalyst driver, FreeSync seamlessly synchronizes the monitor and GPU refresh rates to eliminate tearing, stuttering and input lag. Ultra fast 1ms response time and impressive 144Hz refresh rate diminish distractions like blurring and ghosting that can mean the difference between victory and defeat. Whether you're racing around the track or stalking enemies in a first-person shooter, the Full HD resolution delivers sharp, true-to-life imagery.
  • Freesync Premium
    Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • 144 Hz Refresh Rate
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
AOC Gaming G2460PF - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405266
Energy Class
Class F
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Pivot (rotation), swivel, tilt
Voltage
56.54 cm x 24.458 cm x 39.36 cm
6.54 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, FCC, RoHS, REACH, EuP, EAC
Bundled Services
Re-Spawned 3 Year Advance Replacement and Zero Dead Pixel Guarantee / 1 Year One-Time Accident Damage Exchange
Display Type
Energy Class
Class F
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
50 - 146 Hz
Horizontal Refresh Rate
30 - 160 kHz
Video Bandwidth
330 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, i-Care, Flicker Free technology, Zero power switch
56.54 cm x 24.458 cm x 39.36 cm - with stand
6.54 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (dual link) , HDMI , DisplayPort , Headphones , 4 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
330
VESA Mounting Interface
Stand
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
Input Voltage
21 kWh/1000h
Power Consumption (Typical)
22.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Bundled Services
C29N C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.18
C29N C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £11.11
C29N C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £13.89
