AOC F22+ 21.5" 1920 x 1080 5MS DVI-D VGA LCD Monitor
Quicklinx: 843LWS00 Mfr#: F22+
The F22+ will appeal to everybody who attaches great importance to an attractive model combined with outstanding technical features. Thanks to its innovative small folding base the display can be easily placed on every desk and save space. The navigation ring integrated in the frame facilitates easy adjustment.
The display surface offers enough space for large-area presentations and multi-media demonstrations in 16:9 format. The viewing angle of 170°/160° and a high resolution provide for pin sharp images. Absolute color fidelity is achieved by the Dynamic Color Boost (DCB) method.
AOC F22+ - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
300 cd/m²
Contrast Ratio
60000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Voltage
Piano polish
52.6 cm x 8.1 cm x 37.9 cm
4.6 kg
Microsoft Certification
Certified for Windows Vista
DDC-1, DDC-2B, ISO 13406-2, TUV S, CCC, FCC, DDC/CI, RoHS, cULus
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
300 cd/m²
Contrast Ratio
60000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
148 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Eco-Mode, glossy, Dynamic Color Boost
Piano polish
4.6 kg
DVI-D , VGA
Security lock slot (cable lock sold separately), wall mountable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
49 Watt
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 3 years
