AOC E960SDA 19" 1440x900 5MS VGA DVI LED Monitor with Speakers
Quicklinx: 8P2YWS00 Mfr#: E960SDA
This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC e960Sda - Professional Line - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 75 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
44.22 cm x 18.5 cm x 35.953 cm
2.29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, TUV GS, DDC-1, DDC-2B, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 75 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care, Ionic Breeze
2.29 kg
Audio
Speakers - integrated
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Security Slot Type
Kensington security slot
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
