This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
- AOC e960Prda - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel
- Voltage
- AC 120/230 V (50/60 Hz)
- 40.92 cm x 43.22 cm x 21 cm
- 4.77 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 140 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- I-Menu, e-Saver technology, Eco Saving, Screen+
- 4.77 kg
Audio
- Speakers
- VGA , DVI-D
Mechanical
- Tilt Angle
- -5/+15
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 16 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
