AOC E2475PWJ 23.6" 1920x1080 2Mms VGA DVI HDMI LED Monitor with Speakers
Quicklinx: D63KWS00 Mfr#: E2475PWJ
This ergonomically adjustable and energy efficient business monitor boasts DisplayPort and HDMI connectors for high-speed digital input, as well as stereo speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
AOC Pro-line E2475PWJ - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/393963
Energy Class
Class E
Power Consumption (On mode)
17 W
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Voltage
AC 120/230 V
Display Type
Energy Class
Class E
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
2 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
I-Menu, e-Saver technology, Flicker Free technology
Audio
Speakers
DVI , HDMI , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
330
Height Adjustment
130 mm
Wall mountable
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Input Voltage
AC 120/230 V
17 W
17 kWh/1000h
Power Consumption (Typical)
18.03 Watt
Power Consumption Stand by
0.33 Watt
Power Consumption (Off Mode)
0.25 Watt
On / Off Switch
D63K StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £135.75
D63K StarTech.com Dual Monitor Mount - Stackable In Stock £213.39
D63K StarTech.com Dual Monitor Stand In Stock £80.12
D63K StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
