This large widescreen monitor boasts a non-glare LED-backlit TN panel with Full HD resolution. Delivering a response time of only 5 ms and a static contrast of 1000:1, the 70 series member comes well-equipped for both multimedia and office applications. Connect analog signals via D-Sub and digitally via its DVI port. This energy-efficient display fulfils strict sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. The monitor is equipped with intelligent software to reduce energy consumption and comes in a classy, black design with textures finish and integrated speakers. Let this stylish monitor impress you today!
- Size 23.6"
- Resolution 1920x1080@60Hz
- Inputs D-Sub , DVI
- Response time 5 ms
- Features Plug and Play, iCare, i-Menu, e-Saver, Screen+, Vesa Wallmount
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
LED-backlight
AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
- AOC E2470SWDA - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
- 3-year warranty
- Display Type
- Diagonal Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Input Voltage
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £9.15 |
