This 24-inch display combines impressive performance with added features to make your workday more productive. Full HD resolution offers fantastic imagery and vibrant colors, whether you’re editing images or updating a website. High contrast ratios and quick 2ms response time ensure sharp, lag-free viewing for your most demanding applications. Built-in 2-watt speakers and a headphone jack mean you’ll never miss a word of your presentation or video call. And VGA, DVI-D and DisplayPort connectors make it easy to hook up your computer and external devices. While you focus on business, the ergonomic stand lets you work comfortably – adjust the height, swivel and tilt to the ideal position, or pivot the screen from landscape to portrait mode.
Enhanced visual experience
Experience vibrant, accurate colors with a 24-inch LED-backlit LCD monitor that supports 16.7 million colors and a Full HD 1080p resolution, providing clear, vivid images from any angle with a 170-degree horizontal and 160-degree vertical viewing angle. -
Ergonomic design
Designed with your comfort in mind, the AOC Professional E2460PQ offers extensive display position adjustments including height and tilt, allowing you to customize your viewing experience and work in comfort for extended periods. -
Seamless connectivity
Equipped with multiple interfaces including DVI, DisplayPort, and VGA, this monitor ensures compatibility with a wide range of devices, making it easy to connect to your existing setup without the need for additional adapters. -
Efficient performance
Enjoy an efficient workspace with features like Eco-Mode and e-Saver technology, which help reduce power consumption to just 22 W during operation and less than 0.5 W in standby, all while being ENERGY STAR certified. -
Rapid response
With a 2 ms (gray-to-gray) typical response time, this monitor delivers smooth images without streaking, blurring, or ghosting, perfect for fast-paced videos, graphics design, and gaming.
- AOC Professional E2460PQ - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.54 cm x 24.35 cm x 39.36 cm
- 6.38 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, RoHS, ISO 9241-307, EuP
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 165 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Eco-Mode, e-Saver technology
- Black
- 56.54 cm x 24.35 cm x 39.36 cm - with stand
- 6.38 kg
Audio
- Speakers
- VGA , DVI-D (HDCP) , DisplayPort
Mechanical
- Tilt Angle
- -5/+22
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £22.43 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £14.85 |
