This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energyconsumption at the same time. The environmentally friendly display comes in an elegant, textured finish.
- AOC Value e2460Phu - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Speaker
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.54 cm x 24.45 cm x 52.42 cm
- 6.54 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- TUV GS, DDC-1, DDC-2B, FCC, DDC/CI, RoHS, ISO 9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 37 kWh
- Diagonal Size
- 24"
- Built-in Devices
- Speaker
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care, Ionic Breeze
- 6.54 kg
Audio
- Speakers - stereo - integrated
- VGA , HDMI , DVI-D , USB
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 178
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x USB cable , 1 x power cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 25 W
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- OS Required
- Microsoft Windows 7
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
