AOC E2270SWN 21.5" 1920x1080 5ms VGA Black Monitor
Quicklinx: 920ZWS00 Mfr#: E2270SWN
This LED-backlit monitoris perfectly suited for standard office and home applications. Coming in a black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy.
  • Efficient energy use
    With an ENERGY STAR rating, this monitor balances performance with energy efficiency, consuming only 14.9 W in on mode. This makes it an eco-friendly choice for both your wallet and the environment.
  • Crisp and clear visuals
    The 21.5-inch LED-backlit LCD monitor boasts Full HD 1080p resolution, providing sharp, clear images with a dynamic contrast ratio of 20,000,000:1. Coupled with a WLED backlight, it ensures vivid colors and deep blacks.
  • Seamless connectivity
    Equipped with a VGA interface, this monitor offers reliable connectivity for a wide range of devices, ensuring compatibility with both legacy and current technology without the need for adapters.
AOC E2270SWN - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405270
Energy Class
Class E
Power Consumption (On mode)
14.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
50.34 cm x 17.6 cm x 37.45 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
C-Tick, BSMI, CB, CCC, FCC, RoHS, ISO 9241-307, cTUVus, CECP, CEL, EPA
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
+90 / -90
Vertical Viewing Angle
+60 / -60
Backlight Technology
WLED
2.7 kg
VGA
Mechanical
VESA Mounting Interface
100 x 100 mm
Input Voltage
14.9 W
14.9 kWh/1000h
Power Consumption (Typical)
18 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
920Z StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
920Z StarTech.com Articulating Monitor Arm In Stock £121.96
920Z StarTech.com Dual Monitor Stand In Stock £82.12
920Z StarTech.com TV/Monitor Arm - Wallmount In Stock £85.61
920Z StarTech.com Monitor Arm - Heavy Duty In Stock £95.48
