AOC E2070SWN 19.5" 1600x900 5ms VGA Black Monitor
Quicklinx: 96GLWS00 Mfr#: e2070Swn
This LED-backlit monitor delivers a solid performance for standard office and home applications. Coming in a classy black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time for crisp, blur-free images. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy. The eco-friendly Series 70 fulfils demanding sustainability certificates such as Energy Star 6.0 and EPEAT Silver and is prepared for both VESA wall mount and Kensington security devices.
  • 5ms Response Time
    A pixel response time of 5ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
  • LED-backlight
    AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
AOC E2070SWN - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/393942
Energy Class
Class E
Power Consumption (On mode)
13.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
200 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
46.5 cm x 15.6 cm x 34.4 cm
2.27 kg
Environmental Standards
EPEAT Silver
C-Tick, BSMI, DDC-2B, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, cTUVus, CECP
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
2.27 kg
VGA
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Wall mountable
Input Voltage
13.8 W
13.8 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
Limited warranty - 3 years
