AOC E1659FWU 15.6" 1366x768 8ms USB LED Monitor
Quicklinx: 96GYWS00 Mfr#: e1659Fwu
Productivity anywhere you go
More screen real-estate significantly increases productivity. With your monitor connected to your laptop you can be efficient even outside your home or office – when travelling or, visiting customers.
USB monitor 3.0
Discover the freedom and flexibility of AOC’s myConnect USB monitors. A single USB cable connects your laptop to the directly to the display, completely eliminating the need for extra media cables and a power supply. The USB cable transfers data to the screen, plus acts as an energy-efficient power source. For work or play, these monitors offer optimal portability. Besides ultra-easy connectivity, the innovative stand offers you a variety of viewing options.
Flexi-Stand
The E1659FWU has a foldable flexi-stand for viewing in landscape or portrait mode. Landscape mode is ideal for video conferences, presentations and Excel sheets, while the Portrait mode conveniently gives you an easy vertical view of your instant messaging program, or sidebars such as search results.
Auto-Pivot
Change the orientation of the monitor to automatically align screen content (included AOC i-Menu software needed to activate).
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • USB monitor
    Discover the freedom and flexibility of AOC's myConnect USB monitors. A single USB cable connects your laptop to the directly to the display, completely eliminating the need for extra media cables and a power supply. The USB cable transfers data to the screen, plus acts as an energy-efficient power source. For work or play, these monitors offer optimal portability. Besides ultra-easy connectivity, the innovative stand offers you a variety of viewing options.
AOC E1659FWU - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/419912
Energy Class
Class C
Power Consumption (On mode)
8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
500:1 / 20000000:1 (dynamic)
Colour Support
16.7 million colours (8-bit)
Input Connectors
USB
Display Position Adjustments
Tilt
Glossy piano black
36.98 cm x 2.22 cm x 21.914 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, RoHS, cTUVus, cCSAus
3-year warranty
Display Type
Energy Class
Class C
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Backlight Technology
WLED
FlexStand
Glossy piano black
1.2 kg
Mechanical
Tilt
VESA Mounting Interface
75 x 75 mm
Carrying case
Backlight Life
50,000 hours
8 W
8 kWh/1000h
Power Consumption (Typical)
7 watt
Power Consumption Stand by
0.03 watt
Power Consumption (Off Mode)
0 watt
Shipping Width
44.2 cm
Shipping Depth
8.5 cm
Shipping Height
29.5 cm
Shipping Weight
1.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
