240Hz refresh rate, 0.5ms response time and low input lag enable the AOC C27G2ZU to provide a perfectly smooth performance. With its curved design, height adjustment and swivel ability, the monitor can be adjusted to individual needs. It comes with FreeSync Premium and G-Sync compatibility.
FreeSync Premium
Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate. -
Curved
Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience. -
0.5 ms
A pixel response time of 0.5 ms means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
240Hz
240Hz completely unleashes top end GPUs, bringing unprecedented fluidity to the picture on your screen. With every detail brought sharply into focus and every movement shown with crystal clarity, feel your reactions become one with the action and elevate your game. -
Low Input Lag
Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs. -
G-menu
AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience for any AOC or AGON monitor -
6 Games mode
Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy. -
Height adjustment
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of gaming comfort.
- AOC Gaming C27G2ZU/BK - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/399270
- Energy Class
- Class E
- Power Consumption (On mode)
- 21 W
- Curved Screen
- Adaptive-Sync Technology
- NVIDIA G-SYNC, AMD FreeSync Premium
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 240 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 0.5 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 120% sRGB, 89% Adobe RGB
- Input Connectors
- 2xHDMI, DisplayPort
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Black, red
- 61.237 cm x 22.74 cm x 52.86 cm
- 5.5 kg
- GOST, FCC, ISPO
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class E
- Diagonal Size
- 27"
- Curved Screen
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 0.5 ms (MPRT)
- Vertical Refresh Rate
- 48 - 240 Hz
- Horizontal Refresh Rate
- 30 - 255 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Anti-glare, Flicker Free technology, Hard Coating (3H), borderless
- Black, red
- 61.237 cm x 22.74 cm x 52.86 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x HDMI , DisplayPort 1.2 , 4 x USB 3.2 Gen 1 , Headphones
Mechanical
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- GOST, FCC, ISPO
- Input Voltage
- 21 W
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption HDR (On mode)
- 21 kWh/1000h
- Power Consumption (Typical)
- 31 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 61.237 cm - depth: 7.316 cm - height: 36.733 cm - weight: 4.1 kg
- Shipping Width
- 68.6 cm
- Shipping Depth
- 21.4 cm
- Shipping Height
- 52.3 cm
- Shipping Weight
- 7.8 kg
- Limited warranty - 3 years
