AOC C24G2AE/BK - LED 24"  1920 x 1080 Full HD (1080p)
Quicklinx: GMS2WS00 Mfr#: C24G2AE/BK
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DisplayPort, HDMI
£159.24 ex VAT
£191.08 inc VAT
This 165 Hz display impresses with its lightning-fast 1 ms response time and VA panel, generating extraordinarily powerful colours. The FreeSync Premium support guarantees perfect synchronisation between monitor and GPU.
  • Minimal bezel distraction for the ultimate battle station
    Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
  • 165Hz Refresh Rate
    A 165Hz refresh rate, well over twice the industry standard of 60Hz, makes games run smooth as silk. Realize the potential in your graphics card. Forget screen tearing and forget motion blur. Feel your reflexes become one with the action. Never look back.
  • Freesync Premium
    Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate.
  • 1500R Curved
    Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
  • 6 Games Mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • AOC Game Color and Shadow control
    Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust grey levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • AOC G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience.
  • Good for Console Gaming
    Many of our top-notch monitors are not only designed to work with PC towers but are also compatible with consoles. You can easily plug them into your Xbox or PlayStation and enjoy the great image quality. The monitors support up to 120Hz, so even the newest generation models run on the highest settings.
AOC Gaming C24G2AE/BK - LED monitor - curved - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/393440
Energy Class
Class E
Power Consumption (On mode)
17.9 W
Curved Screen
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.27156 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
120% sRGB, 89% Adobe RGB
Input Connectors
2xHDMI, 2xDisplayPort, VGA
Display Position Adjustments
Pivot (rotation), tilt
Screen Coating
3H Hard Coating
Voltage
Black, red
53.61 cm x 22.74 cm x 37.53 cm
3.84 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.6"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27156 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Game mode, FPS Mode, Flicker Free technology, RTS Mode, borderless, Racing Mode, Low Framerate Compensation (LFC)
Black, red
53.61 cm x 22.74 cm x 37.53 cm - with stand
3.84 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , 2 x DisplayPort 1.2 , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-4/+21.5
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
17.9 W
17.9 kWh/1000h
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 53.61 cm - depth: 22.74 cm - height: 50.53 cm , With stand (lowest position) - width: 53.61 cm - depth: 22.74 cm - height: 37.53 cm , Without stand - width: 53.61 cm - depth: 6.85 cm - height: 32.1 cm
Shipping Width
73 cm
Shipping Depth
16 cm
Shipping Height
48 cm
Shipping Weight
6.11 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: AOC
