This 165 Hz display impresses with its lightning-fast 1 ms response time and VA panel, generating extraordinarily powerful colours. The FreeSync Premium support guarantees perfect synchronisation between monitor and GPU.
Minimal bezel distraction for the ultimate battle station
Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station. -
165Hz Refresh Rate
A 165Hz refresh rate, well over twice the industry standard of 60Hz, makes games run smooth as silk. Realize the potential in your graphics card. Forget screen tearing and forget motion blur. Feel your reflexes become one with the action. Never look back. -
Freesync Premium
Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate. -
1500R Curved
Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience. -
Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Low Input Lag
Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs. -
6 Games Mode
Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy. -
AOC Game Color and Shadow control
Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust grey levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display. -
AOC G-menu
AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience. -
Good for Console Gaming
Many of our top-notch monitors are not only designed to work with PC towers but are also compatible with consoles. You can easily plug them into your Xbox or PlayStation and enjoy the great image quality. The monitors support up to 120Hz, so even the newest generation models run on the highest settings.
- AOC Gaming C24G2AE/BK - LED monitor - curved - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/393440
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.9 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 165 Hz
- Pixel Pitch
- 0.27156 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 120% sRGB, 89% Adobe RGB
- Input Connectors
- 2xHDMI, 2xDisplayPort, VGA
- Pivot (rotation), tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, red
- 53.61 cm x 22.74 cm x 37.53 cm
- 3.84 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class E
- Diagonal Size
- 23.6"
- Curved Screen
- Yes (1500R)
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27156 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 1 ms (MPRT)
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Game mode, FPS Mode, Flicker Free technology, RTS Mode, borderless, Racing Mode, Low Framerate Compensation (LFC)
- Black, red
- 53.61 cm x 22.74 cm x 37.53 cm - with stand
- 3.84 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- 2 x HDMI , 2 x DisplayPort 1.2 , VGA , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -4/+21.5
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.9 W
- Power Consumption SDR (On mode)
- 17 kWh/1000h
- Power Consumption HDR (On mode)
- 17 kWh/1000h
- Power Consumption (Typical)
- 27 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Dimensions & Weight Details
- With stand (highest position) - width: 53.61 cm - depth: 22.74 cm - height: 50.53 cm , With stand (lowest position) - width: 53.61 cm - depth: 22.74 cm - height: 37.53 cm , Without stand - width: 53.61 cm - depth: 6.85 cm - height: 32.1 cm
- Shipping Width
- 73 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 48 cm
- Shipping Weight
- 6.11 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
