With Full HD resolution and high contrast ratios, the 23.6-inch M2470SWH display offers brilliant picture quality and sharp, clear imagery - even on the darkest areas of the screen. Perfect for a range of home computing requirements, this monitor really excels at fast-paced entertainment like games and movies with ultra-fast 1 ms response time for lag-free action. Advanced MVA panel technology delivers ultra-wide viewing angles of 178 degrees to ensure you'll see every detail, no matter where you're sitting. Integrated VGA and HMDI ports make it easy to connect your computer, media center, game console and more, plus the built-in speakers and headphone jack are ideal for listening to music or catching up with friends.
MVA Panel
The MVA (Multi-Domain Vertical Alignment) panel displays deeper blacks and a -high contrast for extra vivid and bright images. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Full HD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
- AOC M2470SWH - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/405265
- Energy Class
- Class E
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Voltage
- AC 100/230 V (50/60 Hz)
- Black
- 55.14 cm x 22.1 cm x 40.04 cm
- 3.58 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.6"
- Viewable Size
- 24"
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 165 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Tilt
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP, i-Menu, e-Saver technology, Screen+, i-Care
- Black
- 55.14 cm x 22.1 cm x 40.04 cm - with stand
- 3.58 kg
Audio
- Speakers - stereo - integrated
- VGA , 2 x HDMI , Headphones
Mechanical
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable , 1 x HDMI cable , 1 x power cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption SDR (On mode)
- 17.4 kWh/1000h
- Power Consumption (Typical)
- 17.96 watt
- Power Consumption Stand by
- 0.5 watt
- Power Consumption Sleep
- 0.19 watt
- 0.3 watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
AOC AOC Value M2470SWH - LED monitor - 23.6" (23.6" viewable) -
