15.6" Full HD portable IPS display with USB-C connectivity
The latest USB-C powered portable display from AOC, I1601FWUX boasts a vivid 15.6" IPS display with wide viewing angles (160/160°) and 5 ms GtG. Includes smart cover and auto-pivot mode.
16" Class USB Type-C Portable Monitor
Newest USB Portable Monitor from AOC Featuring Type-C Connectivity and Gorgeous IPS Full High Definition Display
* 1920x1080 Full HD Resolution
* IPS Panel
* USB Type-C Powered
* 5ms Response Time
* Auto-pivot for Landscape or Portrait Modes
* Flexi-Stand Smart Cover
* LowBlue Mode
USB-C
One cable is all you need. The USB-C technology carries both the power and the display signal to the screen in one cable. It not only looks ultra-clean and sleek but also greatly improves portability of the monitor. -
Portable, elegant solution
The I1601FWUX looks gorgeous and is durable with its metal alloy case. While being just 8.5 mm thick and weighing ultra-light 800 g it is easy to travel with for work or study. It also easily fits in most notebook bags. -
Smart cover
The included smart cover protects your display inside or outside your bag against dirt and damage. When the display is in use, the cover acts as a flexible screen holder, in portrait or landscape mode. -
Auto-Pivot
Change the orientation of the monitor to automatically align screen content (included AOC i-Menu software needed to activate). -
Business outside home and office
Your office is where you are and moves with you, every day and everywhere. Working with a laptop provides you with mobility but setting up an external monitor is one of the best hacks for improving your productivity. AOC portable solutions help you to connect your laptop through different types of connector systems, so efficiency and flexibility are with you wherever you go. According to the monitor you chose, in fact, you will benefit from the USB-C if you have an AOC I1601FWUX, or the USB 3.0 if you are using the AOC I1659FWUX. -
Travelling and commuting
If you work on the go, whether you're commuting or often working far from home, you need to boost your productivity in places and situations when a complete desktop setup is just impossible and unlikely to have. With the lightweight and easy-to-handle size of AOC portable monitors, you can always be efficient … anytime, anywhere. Working has never been so easy: when visiting your customers, their ergonomics help you focus on the core of your meetings! -
Business meetings
An AOC portable monitor is the perfect solution for business meetings. You can share with your customers and partners a document, or a presentation, while keeping an eye on all other apps you need for work on your laptop. This helps in delivering tasks with no distractions, for you and your audience. -
Home use – Solve the "too little space issues"
Sometimes a traditional monitor is not what you're really looking for, the more so if you live in a small apartment and you can't have a complete desktop layout. But AOC has the perfect solution, in roughly 16", that can assure you more screen space and more comfort. -
Home use – Multi setup
Portable monitors are also worthy allies in multi-monitor set-ups at home. They are a space-efficient and powerful solution that can be used in your home setup for complete and extensive visualization, but also a solution that can fit everywhere in your house for any need. Thanks to a single USB cable that transfers data to the screen and acts as an energy-efficient power source, you can enhance your work efficiency while maintaining a clear and sleek desk for a stylish solution for any workplace or home interior.
- AOC I1601FWUX - LED monitor - Full HD (1080p) - 16"
- LED-backlit LCD monitor - 16"
- Energy Class
- Class B
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 700:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 262,000 colours
- Input Connectors
- USB-C
- Tilt
- Black
- 37.62 cm x 0.85 cm x 23.52 cm
- 824 g
- RoHS, REACH
- 3-year warranty
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 16"
- Viewable Size
- 16"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- Colour Support
- 262,000 colours
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 160
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Foldable stand, landscape mode, portrait mode
- Black
- 37.62 cm x 0.85 cm x 23.52 cm - with stand
- 824 g
- USB-C/DisplayPort Alt Mode
Mechanical
- Tilt
- Tilt Angle
- +5/+25
- Cables Included
- 1 x USB-C cable
- RoHS, REACH
- Power Consumption SDR (On mode)
- 4.9 kWh/1000h
- Power Consumption (Typical)
- 8 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Shipping Width
- 29.5 cm
- Shipping Depth
- 8.4 cm
- Shipping Height
- 44.2 cm
- Shipping Weight
- 1.547 kg
- Limited warranty - 3 years
