AOC AGON Series 49" Curved SDQHD Premium Gaming Monitor
Quicklinx: HTNDWS00 Mfr#: AG493UCX2
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort, USB-C
£713.04 ex VAT
£855.64 inc VAT
Double the in-game immersion with the curved AG493UCX2: thanks to the vast screen space of 49" (32:9) and a stunning Dual-QHD 5K resolution, you face a razor-sharp image whichever way you look. A gushing refresh rate of 165Hz and FreeSync Premium Pro ensure the smoothest images for even more realism.
  • 49" ultra-wide
    With a size of 49", ultra-wide displays provide double more screen space compared to regular monitors. The extra size makes for more efficient use of space and allows for an unprecedented 32:9 ratio.
  • 1800R curved
    Curved design wraps around you putting you at the center of the action and provides an immersive gaming experience.
  • 1ms response time
    A pixel response time of 1ms means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • 165Hz refresh rate
    A 165Hz refresh rate, well over twice the industry standard of 60Hz, makes games run smooth as silk. Realize the potential in your graphics card. Forget screen tearing and forget motion blur. Feel your reflexes become one with the action. Never look back.
  • Freesync Premium Pro
    The AMD FreeSync Premium Pro Technology ensures that the GPU's and monitor's refresh rates are synchronized, which provides a fluid, tear free gaming experience at highest performance. With AMD FreeSync Premium Pro you can enjoy the smooth gameplay at peak performance with exceptional, crystal-clear HDR spectrum of colors and luminosity nuances, providing lifelike gaming imagery.
  • VESA Certified DisplayHDR 400
    Even the lowest level of High Dynamic Range (HDR) feature poses a significant upgrade to common monitors. The peak luminance of 400 cd/m² enables your display to hone the picture quality with a manifold color spectrum and more diverse contrast. The VESA-certificate ensures richness of detail and realistic portrayals of game and film worlds.
  • USB-C
    Simplify the connections with one cable only. The USB-C connection provides DisplayPort Alternate Mode for transferring high-resolution video signals from a notebook to the monitor while simultaneously charging the notebook's battery from the monitor with USB power delivery. Additionally, the USB 3.1 ensures lightning-fast data transmission, so even transferring a 4K movie can be done in less than one minute.
  • AOC Game Color and Shadow Control
    Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust gray levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favor of raw response time, giving the ultimate edge in hair trigger stand offs.
  • 6 games mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customize your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • AOC G-Menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience.
AOC Gaming AG493UCX2 - AGON Series - LED monitor - curved - 49" - HDR
LED-backlit LCD monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/689000
Energy Class
Class G
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
KVM Switch, USB 3.1 Gen 1/USB-C hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 (DisplayPort: 165 Hz, HDMI: 75 Hz, USB-C: 120 Hz)
Pixel Pitch
0.2331 mm
Brightness
550 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
100% NTSC (CIE 1976), 121.57% sRGB (CIE 1931), 98% Adobe RGB (CIE 1976), 90.1% Adobe RGB (CIE 1931)
Input Connectors
3xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Textured black
119.44 cm x 30.8 cm x 46.76 cm
14.4 kg
WHQL, FCC, RoHS, WEEE, cTUVus
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
49"
Viewable Size
48.8"
Curved Screen
Yes (1800R)
Built-in Devices
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
550 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
30 - 250 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, game mode, Flicker Free technology, AOC Shadow Control, Picture-in-Picture, Low Blue Light technology, 3-sided frameless
Textured black
119.44 cm x 30.8 cm x 46.76 cm - with stand
14.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort 1.4 , USB-C/DisplayPort Alt Mode with Power Delivery (power up to 65W) , 3 x HDMI , 3 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (fast charging) , Headphones
Mechanical
Tilt Angle
-3.5/+13.5
Swivel Angle
30
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Remote control
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB cable , 1 x USB-C to USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
55 kWh/1000h
Power Consumption HDR (On mode)
105 kWh/1000h
Power Consumption (Typical)
68 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
AOC eSaver, AOC G-Menu
Dimensions & Weight Details
With stand (lowest position) - width: 119.44 cm - depth: 30.8 cm - height: 46.76 cm - weight: 14.4 kg , With stand (highest position) - width: 119.44 cm - depth: 30.8 cm - height: 56.76 cm - weight: 14.4 kg , Without stand - width: 119.44 cm - depth: 15.324 cm - height: 36.94 cm
Shipping Width
130.8 cm
Shipping Depth
55.3 cm
Shipping Height
42 cm
Shipping Weight
20.8 kg
Limited warranty - 3 years
Diagonal Size: 49in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: AOC
Price Range Ex VAT: £500 - £750
