AOC AGON AG251FZ LCD Monitor 24.5" 1920x1080 400 cd/m
Quicklinx: CVMXWS00 Mfr#: AG251FZ
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, DVI, HDMI, HDMI(MHL) + 1 more
16 in stock
£260.40 ex VAT
£312.48 inc VAT
Screen tearing, motion blur and ghosting effects are some of the annoying problems competitive gamers can face during extensive gaming sessions. With a refresh rate of 240 Hz, Adaptive-Sync technology and a response time of only 1 ms, the 25" premium gaming monitor AOC AGON AG251FZ puts an end to these issues once and for all. Instead, competitive gamers are able to enjoy smooth and highly response gameplay and graphics. AOC Shadow Control enhances image quality by adjusting the shadow and light levels on the screen so that the screen is neither too washed out nor too dark. To make long gaming sessions more enjoyable, the AG251FZ is equipped with the AOC Ergo Dial Base, allowing for height, tilt and swivel adjustment. An integrated height scale enables you to always set up the monitor in your preferred setting and suited to your individual needs. The display is also easy on the eyes, with AOC Flicker-free technology reducing the flicker that so often causes eye discomfort and fatigue.
AOC AGON AG251FZ - LCD monitor - 24.5"
LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Aspect Ratio
16:9
Native Resolution
1920 x 1080 at 240 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort, MHL
56.665 cm x 21.825 cm x 54.521 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, DICOM Part 14, REACH, TUV Bauart, EuP, EAC, TCO Displays 7.0
3-year warranty
Display Type
LCD monitor
Energy Class
Class B
44 kWh
30 W
Diagonal Size
24.5"
Viewable Size
24.5"
Built-in Devices
USB 3.0 hub
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
I-Menu, e-Saver technology, Adaptive-Sync technology
6.5 kg
Audio
Output Power / Channel
3 Watt
VGA (HD-15) , DVI , 2 x HDMI (Type A) , MHL , DisplayPort , 4 x USB 3.0 upstream (USB)
Mechanical
Tilt Angle
-3.5/+21.5
Swivel Angle
40
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, Flicker-free technology, HDCP Compliant
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
AC 100 - 240 V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
AOC AGON AG251FZ LCD Monitor 24.5 Bundle deal on AOC AGON AG251FZ LCD Monitor 24.5" 1920x1080 400 cd/m
£351.94
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: HDMI(MHL)
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
