AOC 34" Curved WQHD Premium Gaming Monitor
Quicklinx: HTNBWS00 Mfr#: CU34G2XP/BK
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 1ms
Interfaces: HDMI, DisplayPort
18 In Stock
£249.57 ex VAT
£299.48 inc VAT
The CU34G2XP/BK, a 34-inch curved ultrawide monitor, goes beyond gaming, offering an immersive visual experience for design, content creation, and gaming. With a stunning WQHD resolution of 3440x1440, an impressive 180Hz refresh rate, and a rapid 1ms GtG response time, it ensures ultra-smooth visuals and eliminates motion blur, allowing you to relax and feel like you're inside the game The HDR400 support enriches colours and details, making it an ideal choice for creative professionals who demand precision in their work.
  • 180Hz Refresh Rate
    Competitive and intense gaming demands the best technology to ensure lag-free, smoother gaming. This AGON by AOC monitor features a 180Hz refresh rate, making it 3x faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them very difficult targets to hit. A 180Hz frame rate restores those critical missing images back onto the screen, revealing enemy movements in ultra-smooth motion, letting you more easily target. With this AGON by AOC gaming monitor, you won't have to put up with input-lag and screen tearing.
  • 1ms Response time GTG - Grey-to-Grey
    GtG stands for Grey-To-Grey and represents how long it takes for one pixel to change between one gray level to the next. In gaming, every millisecond counts and can be the differentiator between hitting or missing a shot. Fast response time also eliminates ghosting and motion blur.
  • Wide QHD (WQHD) Resolution
    With 3440 x 1440 resolution, Wide Quad HD (WQHD) offers superior picture quality and crisp imagery that reveals every detail. The widescreen 21:9 aspect ratio is perfect for watching movies in an expansive format or immersing yourself in the latest game, plus it offers more space when it's time to work. True 8-bit colour provides a broad colour palette for vibrant, natural-looking images.
  • Vesa Certified DisplayHDR 400
    Even the lowest level of High Dynamic Range (HDR) feature poses a significant upgrade to common monitors. The peak luminance of 400 cd/m enables your display to hone the picture quality with a manifold colour spectrum and more diverse contrast. The VESA-certificate ensures richness of detail and realistic portrayals of game and film worlds.
  • 6 Games Mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • AOC G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience.
AOC Gaming CU34G2XP/BK - LED monitor - curved - 34" - HDR
LED-backlit LCD monitor - 34"
Curved Screen
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 180 Hz
Pixel Pitch
0.23175 mm
Contrast Ratio
4000:1 / 80000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
1 ms (grey-to-grey), 1 ms (MPRT), 0.5 ms (grey-to-grey min)
Gaming
Colour Gamut
126.5% sRGB (CIE 1931), 120.9% sRGB (CIE 1976), 93.3% DCI-P3 (CIE 1931), 96.3% DCI-P3 (CIE 1976), 126.5% Adobe RGB (CIE 1931), 120.9% Adobe RGB (CIE 1976), 89.6% NTSC (CIE 1931), 105.4% NTSC (CIE 1976), 126.5% BT.709 (CIE 1931), 120.9% BT.709 (CIE 1976), 66.9% BT.2020 (CIE 1931), 70.2% BT.2020 (CIE 1976)
Input Connectors
2xHDMI, 2xDisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Haze 25%, 3H Hard Coating, anti-glare
Voltage
AC 100-240 V (50/60 Hz)
80.83 cm x 23.74 cm x 52.82 cm
8.02 kg
Display Type
Diagonal Size
34"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.23175 mm
Pixel Per Inch
109.7
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Gamut
Response Time
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Flicker Free technology, Adaptive-Sync technology, PIP support, PBP, SmartImage, FPS Mode, Racing Mode, RTS Mode, game mode, 3-sided frameless
80.83 cm x 23.74 cm x 52.82 cm - with stand
8.02 kg
2 x HDMI (HDCP 2.2) , 2 x DisplayPort 1.4 , Audio line-out , 4 x USB downstream
Mechanical
Tilt Angle
3.5/21.5
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
VESA
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
59 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 80.83 cm - depth: 23.74 cm - height: 52.82 cm - weight: 8.02 kg , Without stand - width: 80.83 cm - depth: 10.29 cm - height: 36.75 cm - weight: 6.51 kg
Shipping Width
90.3 cm
Shipping Depth
54.8 cm
Shipping Height
28 cm
Shipping Weight
12 kg
Diagonal Size: 34in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: AOC
