AOC 32" UHD (4K) Console Gaming Monitor
Quicklinx: HTN7WS00 Mfr#: U32G3X/BK
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£481.24 ex VAT
£577.48 inc VAT
The G-Sync compatible U32G3X/BK boasts a remarkable 31.5-inch display, showcasing stunning 4K UHD resolution at 3840x2160 for an unrivaled level of visual clarity. With an ultra-responsive 1ms GtG response time and a high 144Hz refresh rate, this monitor redefines your gameplay. Immerse yourself in the heat of battle or explore vast virtual worlds with unmatched precision and smoothness.
  • Picture by Picture (PbP)
    Picture by Picture is a feature that allows you to make use of multiple sources (e.g. from your laptop and desktop PC) simultaneously and display them on the same screen. Its commanding overview gives you more control and boosts your efficiency both while streaming, working and playing considerably.
  • Display Port
    DisplayPort offers ultra-fast digital audio and video transmission without quality loss or input lag. Quickly and easily connect a range of devices to your screen, including your computer, laptop, media player, game console and more. It's perfect for professionals as well as the most demanding home users.
  • HDMI 2.1
    The latest standard in HDMI technology further boosts higher refresh rates and resolution. This not only opens new doors for watching content, but also for gamers: HDMI 2.1 enables next generation consoles to reach their maximum performance.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • Low Blue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Dial point for more accurate and precise aiming
    The Dial Point function places an aiming indicator in the centre of screen for helping gamers to play First Person Shooter (FPS) games with an accurate and precise focus.
  • Height adjustable Stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of comfort.
  • Pivot function
    Thanks to its pivot function, your monitor can be rotated by 180° from landscape into portrait mode, especially useful for desktop publishing.
  • UHD (4K) Resolution
    4K Ultra High-Definition (3840 x 2160) resolution delivers ultra-crisp picture quality and allows users to see more on the screen at one time. This provides more screen 'real estate' and shows more detail for sharper and more brilliant images. Whether working on the next beautiful photo, or design, or even just used for productivity, users will marvel at the true, crisp image that only a UHD display can provide.
  • IPS Panel
    IPS panel ensures an excellent viewing experience with lifelike yet brilliant and accurate colours. Colours look consistent no matter from which angle you look at the display
  • Adaptive sync
    Adaptive Sync aligns your monitor's vertical refresh rate with the frame rate delivered by your GPU, making your gameplay and casual gaming experience even more fluid by eliminating stuttering, tearing and judder. This feature is also useful when enjoying videos and other visual media, for a smoother entertainment.
  • 144Hz Refresh Rate
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
AOC Gaming U32G3X/BK - LED monitor - 32" - HDR
LED-backlit LCD monitor - 32"
Energy Class
Class F
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible, AMD FreeSync Premium
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 144 Hz
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
1.07 billion colours (8-bit + FRC)
Colour Gamut
122% sRGB (CIE 1931), 95% DCI-P3 (CIE 1976)
Input Connectors
2xHDMI, 2xDisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Black, red
71.53 cm x 25.88 cm x 58.71 cm
7.79 kg
Europe
WEEE
3-year warranty
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
32"
Viewable Size
31.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
139
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 144 Hz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Czech, Croatian, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
Crosshair Display, PBP, Motion Blur Reduction, Game Color Mode, AOC Low-Blue Technology, Dial Point, 3-sided frameless, AOC Flicker-Free Technology, FPS Counter, Shadow control, PIP support, 16-zone local dimming
Black, red
71.53 cm x 25.88 cm x 58.71 cm - with stand
7.79 kg
Audio
Speakers
2 x HDMI , 2 x DisplayPort 1.4 , Headphones
Mechanical
Tilt Angle
-3.5/+21.5
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
DisplayPort cable - 1.8 m , HDMI cable - 1.8 m
WEEE
Europe
Security Slot Type
Kensington security slot
Input Voltage
32 kWh/1000h
Power Consumption HDR (On mode)
65 kWh/1000h
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 71.53 cm - depth: 25.88 cm - height: 58.71 cm - weight: 7.79 kg , With stand (lowest position) - width: 71.53 cm - depth: 25.88 cm - height: 45.71 cm - weight: 7.79 kg , Without stand - width: 71.53 cm - depth: 4.76 cm - height: 42.18 cm - weight: 6.41 kg
Shipping Width
90.5 cm
Shipping Depth
20.4 cm
Shipping Height
52.8 cm
Shipping Weight
10.89 kg
Limited warranty - 3 years
Diagonal Size: 32in
Response Time: 1ms
Interfaces: HDMI
Brand: AOC
