AOC 32" Curved Full HD Gaming Monitor
Quicklinx: HTN8WS00 Mfr#: C32G2ZE/BK
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
29 In Stock
£171.28 ex VAT
£205.53 inc VAT
FHD, 31.5" VA panel and curvature radius of 1500R create the flawless image quality of the curved AOC C32G2ZE. With only 0.5ms response time, a refresh rate of 240Hz and 300 nits luminance, the monitor provides a smooth and colourful experience.
  • 240Hz Refresh Rate
    240Hz completely unleashes top end GPUs, bringing unprecedented fluidity to the picture on your screen. With every detail brought sharply into focus and every movement shown with crystal clarity, feel your reactions become one with the action and elevate your game.
  • 1500R Curved
    Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience.
  • Freesync Premium
    Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate.
  • Minimal bezel distraction for the ultimate battle station
    Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
  • 6 Games Mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • AOC Game Color and Shadow control
    Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust grey levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • AOC G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience.
  • Good for Console Gaming
    Many of our top-notch monitors are not only designed to work with PC towers but are also compatible with consoles. You can easily plug them into your Xbox or PlayStation and enjoy the great image quality. The monitors support up to 120Hz, so even the newest generation models run on the highest settings.
  • 0.5ms MPRT - Moving Picture Response Time
    MPRT is an acronym for moving picture response time. MPRT technology disables and enables your monitor backlight during picture changes. Through the reduced time a frame is shown on the monitor, "ghosting" and "blurring" effects are reduced, resulting in a smoother, more "fluid" feeling gaming experience.
AOC Gaming C32G2ZE/BK - LED monitor - curved - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/394329
Energy Class
Class F
Power Consumption (On mode)
31.5 W
Curved Screen
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Pixel Pitch
0.3637 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
91% Adobe RGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
70.99 cm x 24.49 cm x 52.44 cm
6.83 kg
TUV, GOST, FCC, RoHS, REACH, ISPO
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3637 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
91% Adobe RGB
Response Time
1 ms (MPRT)
Vertical Refresh Rate
48 - 240 Hz
Horizontal Refresh Rate
30 - 255 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Flicker Free technology, borderless
70.99 cm x 24.49 cm x 52.44 cm - with stand
6.83 kg
2 x HDMI , DisplayPort 1.2 , Headphones
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31.5 W
31.5 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 70.99 cm - depth: 8.498 cm - height: 42.55 cm - weight: 5.67 kg , With stand - width: 70.99 cm - depth: 24.49 cm - height: 52.44 cm - weight: 6.83 kg
Shipping Width
81.3 cm
Shipping Depth
22.5 cm
Shipping Height
60.7 cm
Shipping Weight
9.81 kg
Limited warranty - 3 years
Diagonal Size: 32in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: AOC
