AOC 27G2U/BK 27" IPS Full HD 144Hz Fsync MM
Quicklinx: GJ9SWS00 Mfr#: 27G2U/BK
27" IPS display with 144 Hz refresh rate, 1 ms MPRT and FreeSync Premium.
  • FreeSync Premium
    Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate.
  • 144 Hz
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
  • Minimal bezel distraction for the ultimate battle station
    Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
  • G-Sync Compatible
    Enable flawless picture quality by synchronising new generations of NVIDIA graphics cards with this FreeSync monitor. See the guideline on how to enable the G-Sync compatibility:Guide on how to enable G-sync on your FreeSync monitor*Please refer to NVIDIA website for the complete list of GPUs working with FreeSync monitors
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
  • G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience for any AOC or AGON monitor
  • 6 Games mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • Height adjustment
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of gaming comfort.
AOC Gaming 27G2U/BK - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/419910
Energy Class
Class E
Power Consumption (On mode)
20.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 144 Hz, HDMI: 144 Hz, VGA: 60 Hz)
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (typical), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
120% sRGB
Input Connectors
2xHDMI, VGA, DisplayPort
Display Position Adjustments
Swivel, tilt
Screen Coating
3H Hard Coating
Voltage
61.21 cm x 22.74 cm x 52.59 cm
5.1 kg
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
120% sRGB
Response Time
Vertical Refresh Rate
48 - 144 Hz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Frameless bezel design, Low Blue Light technology
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 watt
DisplayPort , 2 x HDMI , 4 x USB 3.0 , Audio line-in , Audio line-out , VGA
Mechanical
Swivel, tilt
Tilt Angle
3.5/21.5
Swivel Angle
60
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Input Voltage
20.7 W
20.7 kWh/1000h
Power Consumption (Typical)
28 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Shipping Weight
7.43 kg
3-year warranty
