The U27G3X/BK is an absolute powerhouse that delivers stunning 4K UHD resolution at 3840x2160, ensuring every detail comes to life with incredible clarity. Combining a lightning-fast up to 1ms GtG response time and a high 160Hz refresh rate, this monitor guarantees seamless motion and reduced ghosting, providing you with the competitive edge you need for gaming. With HDMI support, the U27G3X/BK offers versatile connectivity options for your gaming devices, making it a comprehensive choice for immersive and responsive gameplay.
Adaptive sync
Adaptive Sync aligns your monitor's vertical refresh rate with the frame rate delivered by your GPU, making your gameplay and casual gaming experience even more fluid by eliminating stuttering, tearing and judder. This feature is also useful when enjoying videos and other visual media, for a smoother entertainment. -
160Hz Refresh Rate
Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 160Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory. -
Antiglare Coating tittle - en
Antiglare Coating des -en -
Picture by Picture (PbP)
Picture by Picture is a feature that allows you to make use of multiple sources (e.g. from your laptop and desktop PC) simultaneously and display them on the same screen. Its commanding overview gives you more control and boosts your efficiency both while streaming, working and playing considerably. -
Display Port
DisplayPort offers ultra-fast digital audio and video transmission without quality loss or input lag. Quickly and easily connect a range of devices to your screen, including your computer, laptop, media player, game console and more. It's perfect for professionals as well as the most demanding home users. -
HDMI 2.1
The latest standard in HDMI technology further boosts higher refresh rates and resolution. This not only opens new doors for watching content, but also for gamers: HDMI 2.1 enables next generation consoles to reach their maximum performance. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort! -
Low Blue Light
AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage. -
Dial point for more accurate and precise aiming
The Dial Point function places an aiming indicator in the centre of screen for helping gamers to play First Person Shooter (FPS) games with an accurate and precise focus. -
Height adjustable Stand
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of comfort. -
Pivot function
Thanks to its pivot function, your monitor can be rotated by 180° from landscape into portrait mode, especially useful for desktop publishing. -
UHD (4K) Resolution
4K Ultra High-Definition (3840 x 2160) resolution delivers ultra-crisp picture quality and allows users to see more on the screen at one time. This provides more screen 'real estate' and shows more detail for sharper and more brilliant images. Whether working on the next beautiful photo, or design, or even just used for productivity, users will marvel at the true, crisp image that only a UHD display can provide. -
IPS Panel
IPS panel ensures an excellent viewing experience with lifelike yet brilliant and accurate colours. Colours look consistent no matter from which angle you look at the display -
Vesa Certified DisplayHDR 400
Even the lowest level of High Dynamic Range (HDR) feature poses a significant upgrade to common monitors. The peak luminance of 400 cd/m enables your display to hone the picture quality with a manifold colour spectrum and more diverse contrast. The VESA-certificate ensures richness of detail and realistic portrayals of game and film worlds.
- AOC Gaming U27G3X - LED monitor - 4K - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Adaptive-Sync Technology
- NVIDIA G-SYNC Compatible
- Panel Type
- Fast IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 (DisplayPort: 160 Hz, HDMI: 144 Hz)
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- HDR Capable
- DisplayHDR 400
- Response Time
- 1 ms (grey-to-grey), 1 ms (MPRT)
- Gaming
- Colour Support
- 1.07 billion colours (8-bit + FRC)
- Colour Gamut
- 96% DCI-P3 (CIE 1976), 94% Adobe RGB (CIE 1976), 127% sRGB (CIE 1931)
- Input Connectors
- 2xHDMI, 2xDisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Black, red
- 61.39 cm x 25.88 cm x 54.46 cm
- 5.23 kg
- Localisation
- Europe
- WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Panel Type
- Fast IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 163
- Contrast Ratio
- HDR Certification
- DisplayHDR 400
- Colour Support
- Colour Gamut
- Response Time
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Czech, Croatian, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
- Crosshair Display, PBP, Motion Blur Reduction, Game Color Mode, AOC Low-Blue Technology, Dial Point, 3-sided frameless, AOC Flicker-Free Technology, FPS Counter, Shadow control, PIP support
- Black, red
- 61.39 cm x 25.88 cm x 54.46 cm - with stand
- 5.23 kg
- 2 x HDMI , 2 x DisplayPort 1.4 , Headphones
Mechanical
- Tilt Angle
- -3.5/+21.5
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- DisplayPort cable - 1.8 m , HDMI cable - 1.8 m
- WEEE
- Localisation
- Europe
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand (highest position) - width: 61.39 cm - depth: 25.88 cm - height: 54.46 cm - weight: 5.23 kg , With stand (lowest position) - width: 61.39 cm - depth: 25.88 cm - height: 41.46 cm - weight: 5.23 kg , Without stand - width: 61.39 cm - depth: 5.2 cm - height: 36.63 cm - weight: 3.88 kg
- Shipping Width
- 80.5 cm
- Shipping Depth
- 16.2 cm
- Shipping Height
- 48.5 cm
- Shipping Weight
- 7.42 kg
- Limited warranty - 3 years
