AOC 27" Full HD Monitor
Quicklinx: HTMSWS00 Mfr#: 27B3CA2
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, USB-C
£124.99 ex VAT
£149.98 inc VAT
Introducing the newest addition to the B3 line– a brilliant 27-inch display featuring an IPS panel for breathtaking visuals with 1920 x 1080 resolution and 100Hz refresh rates. If you're looking for a compact sized monitor but bigger than 23,8-inch , the 27B3CA2 is the ideal choice. Also, it provides USB-C which means it is possible to utilize video signals, power delivery and data transfer at the same time which will improve your productivity. Whether you're working or studying, enjoy a more comfortable and enjoyable viewing experience with the expansive screen size of the 27B3CA2.
  • 100Hz Refresh Rate
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 100Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
  • USB-C Docking
    Simplify the connections with one cable only. The USB-C connection provides DisplayPort Alternate Mode for transferring high-resolution video signals from a notebook to the monitor while simultaneously charging the notebook's battery from the monitor with USB power delivery.
  • FHD Resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • 1ms MPRT Response Time
    The AOC monitor with 1ms MPRT Response reduces significantly the motion blur, making fast-paced action look crisp and clear, providing an edge in reaction-sensitive games. More than speed, the AOC monitor with a 1ms MPRT is a seamless, fluid motion that immerses you in the virtual world. Whether navigating through a fast-paced racing game or engaged in a high-stakes battle, every millisecond counts.
  • Adaptive sync
    Adaptive Sync aligns your monitor's vertical refresh rate with the frame rate delivered by your GPU, making your gameplay and casual gaming experience even more fluid by eliminating stuttering, tearing and judder. This feature is also useful when enjoying videos and other visual media, for a smoother entertainment.
AOC Basic-line 27B3CA2 - B3 Series - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class E
Adaptive-Sync Technology
AMD Adaptive-Sync
USB 3.2 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Brightness
250 cd/m²
Contrast Ratio
1300:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Colour Support
16.7 million colours
Colour Gamut
101.8% sRGB (CIE 1931), 75% DCI-P3 (CIE 1931), 101.4% sRGB (CIE 1976), 80.7% DCI-P3 (CIE 1976), 75.4% Adobe RGB (CIE 1931), 86.9% Adobe RGB (CIE 1976), 72.1% NTSC (CIE 1931), 88.4% NTSC (CIE 1976), 101.8% BT.709 (CIE 1931), 101.4% BT.709 (CIE 1976), 53.8% BT.2020 (CIE 1931), 58.8% BT.2020 (CIE 1976)
Input Connectors
HDMI, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
61.66 cm x 22.95 cm x 45.29 cm
6.93 kg
Plug and Play, WHQL, CB, DDC/CI, ISO 9241-307, TUV Bauart, EAC, FCC Part 15 Class B, UKCA
3-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class E
Diagonal Size
27"
AMD Adaptive-Sync
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 115 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Low Blue Light Mode, Ultra Narrow Bezels, 6-bit + FRC Color Depth, Global Dimming
61.66 cm x 22.95 cm x 45.29 cm - with stand
6.93 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI (HDCP 1.4) , USB-C (DisplayPort Alt Mode, data, power up to 65W) , USB 3.2 Gen 1 downstream , Headphone jack (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
MTBF
30,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
21 kWh/1000h
Power Consumption HDR (On mode)
21 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption (Max)
135 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.66 cm - depth: 22.95 cm - height: 45.29 cm - weight: 6.93 kg , Without stand - width: 61.66 cm - depth: 4.54 cm - height: 35.67 cm - weight: 4.05 kg
Shipping Width
69 cm
Shipping Depth
14.2 cm
Shipping Height
45.3 cm
Shipping Weight
6.93 kg
Limited warranty - 3 years
10 - 85% (non-condensing)
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Interfaces: USB-C
Brand: AOC
