*Comfort, convenience, and performance in a 23.8" Full HD display with DisplayPort8
The 24P2Q is equipped with a flat 23.8" IPS/3FL panel with Full HD resolution and 178°/178° wide viewing angles in a slim 3-sided frameless display. Designed to offer today’s business the heightened productivity they seek, this model is compatible with VGA, DVI, HDMI, and DP and includes a USB 3.2 hub. Equipped with Low Blue Mode and Flicker-Free technology, it can be adjusted, tilted, pivoted, and swivelled to the ideal ergonomic position.
Full Ergonomics
Feel the comfort! AOC's height, tilt and swivel-adjustable stands help you find the most comfortable and healthy position. -
IPS Panel
IPS panel ensures an excellent viewing experience with lifelike yet brilliant and accurate colours. Colours look consistent no matter from which angle you look at the display -
Frameless design
Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side. -
TÜV Rheinland - Certified eye comfort
TÜV Rheinland - Certified eye comfort At AOC we focus on eye protection and eye comfort, to reduce negative symptoms such as eye strain, headaches and blurred vision. That's the reason why we cooperate with the national certification body (NCB) TÜV Rheinland, which acts both as a third-party testing and an eye comfort certification, in an impartial and independent way. This certification answers safety and quality standards demands by users, who are now so sure they have chosen the best product for their workstations. -
Pivot function
Thanks to its pivot function, your monitor can be rotated by 180° from landscape into portrait mode, especially useful for desktop publishing. -
Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
FHD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
Sustainability
At AOC we aim at minimising the environmental impact of our products and comply with latest environmental and regulatory standards. Our business monitors meet the EPEAT, TCO or Energy Star requirements and are made from 85% recycled plastics. They are also packed in fully recyclable brown cardboard with less oil-based ink and made of at least 80% recycled paper. These actions are just the beginning and we continuously improve the product development stages in order to reduce the energy consumption, minimise the level of waste coming from product packaging and introduce the circularity models even further. To know more about our current sustainability strategy, visit the Corporate Social Responsibility page. -
USB Hub
Built-in USB hubs in AOC's monitors bring ease of use and practicality to your desk. Side mounted ports are easily reachable without even looking at them; negating time wasted searching the backside of a PC case to find a free USB port. -
Low Blue Light
AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort! -
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
 - AOC 24P2Q - LED monitor - Full HD (1080p) - 24"
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/419849
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 14 W
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 50000000:1 (dynamic)
- Response Time
 - 4 ms (grey-to-grey)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 107% sRGB, 79% Adobe RGB
- Input Connectors
 - HDMI, DVI, DisplayPort, VGA
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black
 - 54.02 cm x 20.1 cm x 51.3 cm
 - 4.63 kg
- Environmental Standards
 - TCO Certified Displays 9
 - RoHS, Lead-Free, Mercury-free
 - 3-year warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Viewable Size
 - 23.8"
- Built-in Devices
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - WLED
- OSD Languages
 - Multilingual
 - Flicker Free technology, USB 3.0 Fast Charge
 - Black
 - 54.02 cm x 20.1 cm x 51.3 cm - with stand
 - 4.63 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - VGA (HD-15) , DVI , HDMI , DisplayPort 1.2 , 4 x USB 3.2 Gen 1 , Audio line-in , Headphones (mini-jack)
Mechanical
- Tilt Angle
 - -5/+35
- Swivel Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - 1.8 m
- Input Voltage
 - 14 W
- Power Consumption SDR (On mode)
 - 14 kWh/1000h
- Power Consumption (Typical)
 - 20 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - Without stand - width: 54.02 cm - depth: 5.07 cm - height: 32.64 cm
Sustainability Information
- TCO Certified
 - Limited warranty - 3 years
