Enhanced connectivity and stunning visuals in a 23.8" Full HD display with USB-C and KVM.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
Wide viewing angle
Wide Viewing Angle features display colour accurately at viewing angles of up to 178°. This way, it does not matter where you choose to view it from, colours will be displayed perfectly. -
Full Ergonomics
Feel the comfort! AOC's height, tilt and swivel-adjustable stands help you find the most comfortable and healthy position. -
USB-C
Simplify the connections with one cable only. The USB-C connection provides DisplayPort Alternate Mode for transferring high-resolution video signals from a notebook to the monitor while simultaneously charging the notebook's battery from the monitor with USB power delivery. Additionally, the USB 3.1 ensures lightning-fast data transmission, so even transferring a 4K movie can be done in less than one minute. -
Pivot
Thanks to its pivot function, your monitor can be rotated by 180° from landscape into portrait mode, especially useful for desktop publishing.
- AOC 24P2C - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/419811
- Energy Class
- Class E
- Power Consumption (On mode)
- 18 W
- USB 3.2 Gen 1 hub, USB PD 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 107% sRGB, 79% Adobe RGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.02 cm x 20.01 cm x 51.3 cm
- 5.01 kg
- Environmental Standards
- TCO Certified Displays 9
- RoHS, Lead-Free, Mercury-free
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class F
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.2 Gen 1 hub
- USB Power Delivery
- 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Flicker Free technology
- Black
- 54.02 cm x 20.01 cm x 51.3 cm - with stand
- 5.01 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- HDMI , DisplayPort 1.2 , USB-C/DisplayPort Alt Mode (power up to 65W) , 4 x USB 3.2 Gen 1 , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 180
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - 1.8 m
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption HDR (On mode)
- 19 kWh/1000h
- Power Consumption Stand by
- 0.5 watt
- 0.3 watt
- Dimensions & Weight Details
- Without stand - width: 54.02 cm - depth: 5.07 cm - height: 32.64 cm
Sustainability Information
- TCO Certified
- Limited warranty - 3 years
