AOC 24G2U/BK 23.8" IPS FHD 1920x1080 1ms MM HDMI DP USB
Quicklinx: GSSHWS00 Mfr#: 24G2U/BK
Great colours, great speed. Whatever your game - play it on the AOC 24G2U.
  • 1MS MPRT
    A pixel response time of 1ms means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • FreeSync Premium
    Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate.
  • 144 Hz
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
  • Minimal bezel distraction for the ultimate battle station
    Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
  • G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience for any AOC or AGON monitor
  • 6 Games mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • Height adjustment
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of gaming comfort.
AOC Gaming 24G2U/BK - G2 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/388183
Energy Class
Class E
Power Consumption (On mode)
18 W
Adaptive-Sync Technology
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (6-bit)
Colour Gamut
123% sRGB (CIE 1931), 91% Adobe RGB (CIE 1931), 85% NTSC (CIE 1931)
Input Connectors
2xHDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Textured black, textured red
53.905 cm x 22.736 cm x 37.461 cm
4.25 kg
WHQL, CB, FCC, WEEE, TUV Bauart, EAC, ISO 9241-307 Class 1, Mercury-free
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms (MPRT)
Vertical Refresh Rate
48 - 146 Hz
Horizontal Refresh Rate
30 - 160 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Game mode, FPS Mode, Low Blue Light Mode, Flicker Free technology, RTS Mode, USB 3.0 Fast Charge, AOC Low Input Lag mode, AOC Shadow Control, Racing Mode, Low Framerate Compensation (LFC), AOC Game Color, 3-sided frameless
53.905 cm x 22.736 cm x 37.461 cm - with stand
4.25 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort 1.2 , Headphones , 4 x USB 3.0 , Audio line-in , VGA
Mechanical
Tilt Angle
-5/+23
Swivel Angle
64
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
AOC G-Menu
Dimensions & Weight Details
With stand (lowest position) - width: 53.905 cm - depth: 22.736 cm - height: 37.461 cm - weight: 4.25 kg , With stand (highest position) - width: 53.905 cm - depth: 22.736 cm - height: 50.461 cm - weight: 4.25 kg , Without stand - width: 53.905 cm - depth: 4.72 cm - height: 32.21 cm
Shipping Width
60.5 cm
Shipping Depth
18.4 cm
Shipping Height
49.2 cm
Shipping Weight
6.25 kg
Limited warranty - 3 years
