AOC 24B2XDAM 23.8" VA FHD MM DVI HDMI 4ms
Quicklinx: GK9KWS00 Mfr#: 24B2XDAM
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15), DVI
More than 50 In Stock
£75.50 ex VAT
£90.60 inc VAT
Besides looking attractive, frameless designs enable seamless multi-monitor setups. Cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side
Wide Viewing Angle features display color accurately at viewing angles of up to 178°. This way, it does not matter where one choose to view it from, colors will be displayed perfectly
VA Panel
AOC Lowblue Light protects one from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Lowbue Light feature reduces the harmful wavelengths emitted without sacrificing color composition, setting the experience free from the worry of eye damage
  • Frameless design
    Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side.
  • FHD Resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • VA Panel
    VA Panels (Vertical Alignment) display deeper blacks and a high contrast for extra vivid and bright images.
  • Low Blue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
AOC 24B2XDAM - B2 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Power Consumption (On mode)
18 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
54.01 cm x 18.68 cm x 41.98 cm
2.7 kg
FCC, RoHS, REACH
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Flicker Free technology, Adaptive-Sync technology, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless
54.01 cm x 18.68 cm x 41.98 cm - with stand
2.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DVI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m
FCC, RoHS, REACH
Input Voltage
18 W
18 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.01 cm - depth: 18.68 cm - height: 41.98 cm - weight: 2.7 kg , Without stand - width: 53.947 cm - depth: 3.76 cm - height: 32.094 cm
Shipping Width
61.4 cm
Shipping Depth
13.1 cm
Shipping Height
49.2 cm
Shipping Weight
4.5 kg
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DVI
Brand: AOC
