The AOC PDS241 sports an exciting look. Its 3-sides frameless AH-IPS panel is capable of high resolution. The twisted shape of its metal stand houses the power and display cable. Therefore, its backside has an equally clean and sleek look just like its bezelless front side. This single cable is divided in a separate box for power and HDMI connections. Its AH-IPS panel provides accurate colors thanks to AOC's Supercolor WCG technology. AOC's Flicker Free technology regulates the monitor's brightness with a DC backlight system, reducing flicker and thereby relieving eye discomfort and fatigue experienced in longer usage.
- AOC PDS241 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black/silver
- 54.11 cm x 17.85 cm x 41.6 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC, RoHS, cTUVus
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP, i-Menu, e-Saver technology, Screen+, Low Blue Light Mode, Flicker Free technology
- Black/silver
- 54.11 cm x 17.85 cm x 41.6 cm - with stand
- Headphones , HDMI
Mechanical
- Tilt
- Tilt Angle
- -3.5/+21.5
- Included Accessories
- Stand, communication box
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20 W
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7 / 8 / 10
- Dimensions & Weight Details
- Without stand - weight: 3.15 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
