AOC 24" PDS241 LED IPS 1920x1080 Porsche Design Monitor Silver
Quicklinx: CYG7WS00 Mfr#: PDS241
Select:
  • 24"
The AOC PDS241 sports an exciting look. Its 3-sides frameless AH-IPS panel is capable of high resolution. The twisted shape of its metal stand houses the power and display cable. Therefore, its backside has an equally clean and sleek look just like its bezelless front side. This single cable is divided in a separate box for power and HDMI connections. Its AH-IPS panel provides accurate colors thanks to AOC's Supercolor WCG technology. AOC's Flicker Free technology regulates the monitor's brightness with a DC backlight system, reducing flicker and thereby relieving eye discomfort and fatigue experienced in longer usage.
AOC PDS241 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI
Display Position Adjustments
Tilt
Voltage
Black/silver
54.11 cm x 17.85 cm x 41.6 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, RoHS, cTUVus
3-year warranty
Display Type
Energy Class
Class A
30 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, Low Blue Light Mode, Flicker Free technology
Black/silver
54.11 cm x 17.85 cm x 41.6 cm - with stand
Headphones , HDMI
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
Stand, communication box
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
20 W
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Driver
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - weight: 3.15 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 85% (non-condensing)
