The 24-inch E2460SD2 display features Full HD resolution for detailed imagery and a fast 1 ms response time that makes it suitable even for games or movies. Standard VGA and DVI-D connectors make this monitor ideal for a variety of office and home users.
1 ms response time
A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
LED-backlight
AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display
- AOC e2460Sd2 - Value - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 1 ms
- Input Connectors
- DVI-D, VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, EAC
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 1 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- LED backlight
- HDCP, i-Menu, e-Saver technology, Screen+, i-Care
- Black
- VGA , DVI-D
Mechanical
- VESA Mounting Interface
- Wall mountable
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.29 Watt
- Dimensions & Weight Details
- With stand - width: 56.54 cm - depth: 21.93 cm - height: 40.305 cm - weight: 4.64 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
