AOC 23" LED  VGA HDMI With Speakers
Quicklinx: 9139WS00 Mfr#: I2369VM
The 23" Full HD model sets a new milestone in IPS display technology. The fantastic design offers extensive connectivity options, such as D-Sub, two HDMI connectors and a DisplayPort. Its practical MHL interface allows you to hook up your Android mobile devices directly to the monitor. These monitors are known for vivid colours as well as high viewing angle stability. The display comes with a 250 cd/m² brightness, a typical contrast of 1000:1 (dynamic contrast: 50,000,000:1) and a 5 milliseconds response time for your ultimate viewing experience.
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • MHL Connection
    Mobile High-Definition Link (MHL) technology lets you mirror the content from your portable devices directly on this display. Use an MHL cable to connect your smartphone or tablet and bring all your entertainment to life on the large monitor screen with full digital sound. Relax and enjoy your games, movies, photos and apps on the big screen while charging your mobile device at the same time.
  • IPS Panel
  • Display Port
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
AOC I2369VM - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
53.14 cm x 20.4 cm x 39.8 cm
4.89 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, TUV Bauart, ISO 9024-307, EuP, NRTL
3-year warranty
Display Type
Energy Class
Class B
29 kWh
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
4.89 kg
Audio
Speakers
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
75 x 75 mm
Power Supply
Internal
Input Voltage
20 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
9139 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
