AOC 22B2H/EU 22"  LED Monitor Full HD (1080p)
Quicklinx: HF0PWS00 Mfr#: 22B2H/EU
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: VGA (HD-15), HDMI
More than 50 In Stock
£59.03 ex VAT
£70.83 inc VAT
Modernized design and crisp Full HD images. The 22B2H/EU combines a sleek 3-sides frameless panel and VGA and HDMI connectivity. Enjoy working or streaming with wide viewing angles and eye-soothing LowBlue and FlickerFree technologies.
  • Frameless design
    Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side.
  • FHD Resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • VA Panel
    VA Panels (Vertical Alignment) display deeper blacks and a high contrast for extra vivid and bright images.
  • Low Blue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
AOC 22B2H/EU - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/413333
Energy Class
Class E
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
18 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2482 mm
Brightness
200 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
77% Adobe RGB, 98% sRGB
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
Voltage
AC 120/240 V (50/60 Hz)
49.278 cm x 16.294 cm x 38.811 cm
2.1 kg
Environmental Standards
ENERGY STAR Qualified
FCC, EAC
3-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class F
30 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2482 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Low Blue Light Mode, Flicker Free technology, Wide Viewing Angle, 3-sided frameless
49.278 cm x 16.294 cm x 38.811 cm - with stand
2.1 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+21,5
VESA Mounting Interface
100 x 100 mm
HDMI cable - 1.8 m
FCC, EAC
Security Slot Type
Kensington security slot
Input Voltage
18 W
16 kWh/1000h
Power Consumption HDR (On mode)
18 kWh/1000h
Power Consumption (Typical)
20 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
With stand - width: 49.278 cm - depth: 16.294 cm - height: 38.811 cm - weight: 2.1 kg ¦ Without stand - width: 49.278 cm - depth: 3.62 cm - height: 29.268 cm
Shipping Width
55 cm
Shipping Depth
12 cm
Shipping Height
37 cm
Shipping Weight
3.5 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 22in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Brand: AOC
